Rhino 7: Loft Fails
In the attached file there are two curves. Doing LOFT Straight Sections fails silently on V7. It works on V6.
Problem Loft.3dm (2.8 MB)
Loft can’t have sections that touch (AFAIK). In this case it works if one of the touching endpoints is moved away by at least 2x the file tolerance, i.e. 0.02. I guess they can touch actually, using Rebuild or Refit option also makes a surface…
try clicking way out at the ends- Any better?
loft
@Helvetosaur - Loft is OK with sections that touch at one or both ends; the thing that can go south a bit is if only some of a set of curves touch at one end - then the loft style is forced to StraightSections.
