miano
(Miano)
February 22, 2022, 4:42am
1
In the attached file I have two sets of curves. The blue is the original. I tried to a loft on them. It fails silently.
I exploded all the curves and rejoined them to create Red and they loft as expected.
This seemed odd to me so I share.
Problem Loft.3dm.zip (18.6 KB)
miano
(Miano)
February 22, 2022, 5:00am
2
Problem Difference.3dm.zip (155.9 KB)
Related to the main topic, if you do a boolean difference of the small object from the large object, rhino says the result is a solid but it looks like caca.
JP-Mike
February 22, 2022, 5:05am
3
total curves are 5, there is small tiny line like curve , that’s mean one of your curves is not closed that caused the problem
miano
(Miano)
February 22, 2022, 5:14am
4
The bug would be that Rhino is reporting these as Closed Curves when they are open.
JP-Mike
February 22, 2022, 5:19am
5
They are not all open , the four curves that you have are closed , but there is one small line on the curve
if you go to command and type Selopencrv Rhino will define and tells you that you have one open curve
miano
(Miano)
February 22, 2022, 6:11am
6
At some point there should be an error rather than just nothing happening.
wim
(Wim Dekeyser)
February 22, 2022, 6:22am
7
Hi John -
The command line reports:
Unable to loft - select either open or closed curves, but not both.
miano
(Miano)
February 23, 2022, 1:12am
8
Here’s what I learned. Rhino was not reporting a problem with both open or closed curves. UNTIL I rebooted.
There seems to be some stray memory issues. I generally see these with annotations.
