Rhino 7 Hatch bug
Hi all,
I have a problem with the hatch panel in Rhino 7.
When I select curves and run the hatch command the hatch panel opens and then Rhino freezes instantly. I just switched from Rhino 6 where I worked in the same model and had no problems at al.
Are more people dealing with this same issue?
Best regards,
Ties
Update: I tested around using the hatch command on different scales. Rhino crashes when using a small hatch scale on a large surface. In rhino 6 I had no problem doing this.
Can you run SystemInfo in Rhino and copy/Paste the results here?
Large surface + small scale = lots of lines to display
It may be your graphics card isn’t up to the task. Display stuff on Mac V7 is more demanding/difficult than on V6…
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09492, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Educational, build 2020-12-08
License details: Cloud Zoo
Expires on: 4473029-03-06
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H2) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,3
Language: nl-NL (MacOS default)
NVIDIA GeForce GT 750M OpenGL Engine (OpenGL ver:4.1 NVIDIA-14.0.32 355.11.11.10.10.143)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 2 GB
Graphics: NVIDIA GeForce GT 750M
Displays: Color LCD (295dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
NVIDIA GeForce GT 750M (2 GB)
Color LCD (1920 x 1200)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.1.20343.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.1.20343.9492
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.1.20343.9492
I thought about that too and I think you are right.
But why is that? And isn’t that a bad thing?
We removed a cap on the display lines generated for hatch patterns which used to be 130,000 lines in V7 due to bug reports. The current cap is way too large and we are investigating what can be done to fix this.
I am having exactly the same issue.
Best regards,
Michal
same here
