Rhino 7 cannot hatch, shows sorting window then freeze or crash.
It fails even with a single rectangle and my computer definitely has enough memory.
Is there a solution to this? Thank you!
Hello- please run the SystemInfo
command in Rhino and copy/paste the results here.
Thank you and I have copied the system info here.
Rhino 7 SR0 2020-11-9 (Rhino 7, 7.0.20314.03001, Git hash:master @ 9d1a3d02b292e00d3480c301d33f414d91acdcbd)
License type: Educational Lab License, build 2020-11-09
License details: Cloud Zoo
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 10-14-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.87
Secondary graphics devices.
Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-11-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-14-2020
Driver Version: 27.21.14.5687
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
D:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.0.20314.3001
D:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20314.3001
D:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20314.3001
D:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20314.3001
D:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20314.3001
D:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
Hello - please disable VRay in Options > PLugIns page and then close and restart Rhino - does the problem persist?
Yes. The problem won’t happen after disabled Vray. Is there a way of solving it without disabling vray?
Thank you!
Hey Pascal,
I too am experiencing Rhino crashes (actually freezes and i have to hit restart button) with Vray5. 1-3x per day, typically when rendering.
I’'ve uninstalled Vray 5 & reinstalled, seems to work for a few days, then the crashes start again.
Rhino file sizes are around 30mb
I started with eval of Rhino 6, then bought & installed Rhino 7, then uninstalled Rhino 6. So not sure if something left over from R6 is causing problems?
or vray next to vray 5?
thanks,
Glenn
License type: Commercial, build 2020-11-09
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 11-6-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.30
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-6-2020
Driver Version: 27.21.14.5730
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.0.20314.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20314.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20314.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20314.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20314.3001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
Hello - if uninstalling and reainstalling Rhino and VRay does nothing to sort it out, it seems like the best is to have a chat with VRay support. We do not have Vray here to test with.
Thank you for your help!
thanks for the reply, I have not tried uninstall & reinstall of Rhino7 yet.
I’ll give that a shot next break in work & let you know.
Glenn
dug around Vray forum, appears to have been a fur (grass in my case) issue exceeding GPU memory.
Part of the posting about how to correct:
“… Please enable the Fur’s option ‘Level of detail’ and set its ‘Start Distance’ and ‘Rate’ values to 100 (or even less)…”
Glenn
