Hatch issues
Hello, how’s it going? I’m experiencing some issues with hatches. On one hand, after creating a certain number of hatches, Rhino becomes slow/laggy when zooming in/out using the mouse wheel. On the other hand, gray rectangles or graphical errors start to appear, which are resolved when I click. I’ve attached some screenshots for reference.
scrolling
after clicking
scrolling
after clickng
scrolling
It usually happen (from what I’ve experienced) when the pattern scale is too small. Does the issue still happen if you set all patterns to solid ?
They are all solid patterns.
The black areas you see are solid hatches, and when I click on them, the same issue occurs.
Maybe I’m thinking of something unrelated, but could it be that Rhino is limiting the graphics card’s capacity or something similar? Because when I zoom out to see more things, it slows down.
Hi Rodrigo -
That would be the other way around. It sounds like your GPU is not handling Rhino very well. Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR4 2021-3-8 (Rhino 7, 7.4.21067.13001, Git hash:master @ ed629035202f07e8b84a3ee211479ca20bb81b73)
License type: Corporate, build 2021-03-08
License details: Stand-Alone
Windows 10.0.19045 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-16-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 2GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-4-2023
Driver Version: 31.0.15.3758
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Users\Rodrigo\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.5.0\7\Fologram.IO.Rhino3d.Win7.rhp “Fologram for Rhino” 2020.3.5.0
C:\Users\Rodrigo\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23187.1334
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.4.21067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21067.13001
C:\Users\Rodrigo\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Thanks.
You are running a cracked version of an ancient service release of Rhino 7 and probably cracked 3rd party plug-ins. What can possibly go wrong?
Apart from that, you might want to check the power settings in the NVIDIA panel.
