I’ve been noticing some performance issues with Rhino 7 on the last few jobs I worked on. The model starts out fine but as time goes on there develops a small pause after some operations (trimming is an example). I’m running the latest RC.
It’s not file size dependant, as it happens even with very small files. The longer I work on it, the more pronounced the pause becomes. Closing Rhino and re-opening doesn’t solve it. The only way to get rid of those annoying hesitations is to restart the computer. But then it slowly comes back.
But now I have a bigger problem. I can’t get Rhino 7 to open as it gets stuck loading the IronPython plug-in.
It’s been hanging here for about 20 minutes. Rebooting doesn’t solve this. The only way back into Rhino 7 is in safe mode.
Tomorrow I will disable the only plug-in I have loading and see if that helps. In the meantime, I just want to find out from other users if they experience a hesitation after certain commands. I haven’t purchased the licenses for everyone else yet, so I can’t test this myself to try to determine if it’s a Rhino issue or my computer.
Thanks,
Dan
