Rhino 7 export completely breaks my model on 3ds max
So basically, i have tried it all, units scalling on both apps, i have played with the mesh settings, exported it from nurbs, triangle mesh and quad mesh, and its constantly this result.
Any help would be greatly appriciated
I expect it is too far away from 0,0,0 origin. This would be because civil survey data is many times at state plane distances.
Move the model close to 0,0,0. Then run clear all meshes. Then export. Then should clean it up.
Meshes in some formats can be single precision vertex locations, which can limit how large the coordinates can be.
Also, it would be great if you made sure you buy a valid Rhino license and installed a non-cracked version of Rhino from our site. Cracked versions may have modifications that interfere with proper operation, or even worse, carry malware.
