hello dear
i am trying to print with color as PDF and the PC is crashing , it failed to print it
i tried without color which it is black and white and it was great, it worked
can anybody help me with that
i tried again and it was because of the hatch not the color
what is the solution’s for that
guys i have my submission tomorrow ,if any of you could help i will be so grateful
thank you
Hi -
Please run the Rhino SystemInfo
command and copy-paste the result here.
Also, which PDF printer are you using to create the PDF?
thanks Wim ,
im using the one which is in the rhino pdf
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13001, Git hash:master @ aa7902c94c5aa33511e60d30f82b636be43bc85f)
License type: Evaluation, build 2022-03-08
License details: Cloud Zoo
Expires on: 2022-06-17
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 3-8-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 12-8-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.63
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-8-2020
Driver Version: 27.21.14.5763
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22067.13001
C:\Users\moham\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hi @salman_ali
I’d start by updating those drivers - they are very, very old.
HTH, Jakob
Hi -
Also, please update Rhino. The current version is SR18.
Ohh thanks, i will
thank you WIM
i will update
