Rhino 7 Clipping Plane Bug?
It has happened several times now…on different models. When using clipping plane either Rhino freezes or even worse the computer. When I pick up the model in Rhino 6 and repeats the same commands, everything is OK??? Some of my models are size 200-500 MB. But newer the less, no problems in Rhino 6. This happens in Rhino 7. Does Rhino 7 require more memory? As for now, I just have to continue working with R6 :frowning:
Hei Dag -
Could you please run the Rhino SystemInfo command in Rhino 7 and copy-paste the result here?
Mvh,
Hi Wim. Thanks for responding.
C+P of SystemInfo…
Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03001, Git hash:master @ 2cd158094b595f6400479d7cbe511454b6149527)
License type: Commercial, build 2021-04-10
License details: Cloud Zoo
Windows 10.0.17763 SR0.0 or greater (Physical RAM: 7.8Gb)
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display and OpenGL: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 3-8-2019 (M-D-Y). OpenGL Ver: 4.5.0 - Build 25.20.100.6617
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.5
Shading Language: 4.50 - Build 25.20.100.6617
Driver Date: 3-8-2019
Driver Version: 25.20.100.6617
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21100.3001
BR Dag
Hei Dag -
Note that the minimum recommended VRAM is 4GB.
That said, I would start with updating the drivers for that GPU. In terms of GPU drivers, 2019 is ancient. When you open the Rhino Notifications panel, there should be links guiding you to the Intel page.
