Our workflow in the office depends upon the ability to set object level display modes on colored meshes. We need the colors that are assigned to the mesh to be displayed accurately on screen (i.e. these colors cannot pass through a shader in arctic mode, causing them all to be darker).
In Rhino6 this worked perfectly, we would use arctic mode with white objects as the content, and a colored mesh as the analytical result output.
Here is an example of the desired output, achieved using Rhino 6:
In Rhino7, I am not able to display the mesh using colors assigned to the mesh while also displaying surrounding context buildings in arctic view white rendering. The colors are always overridden by the layer colors:
I’m afraid this is not the expected behavior. I am hoping to see the mesh (currently blue) as a gradient of colors from red to yellow… while also simultaneously displaying all the other objects as white shaded volumes.
Here is the SystemInfo:
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05001, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Commercial, build 2021-07-15
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 4000 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 7-7-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.98
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-7-2021
Driver Version: 27.21.14.6298
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Alexanderj\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
Hello - there was no map assigned to the display mode - if I assign a map then it seems to work- here the plane is assigned the custom arctic - is that better?
Thanks again, but I’m afraid we aren’t quite there!
The colors are assigned to the mesh itself, not as a texture map… is there a way to use the mesh’s colors? Assigning the colors to the mesh as a texture map would be extremely brittle.
See the Rhino 6 example if you’re in doubt about the source of the colors.
Ah, OK, vertex colors… I see now, thanks. I can get what I think(?) you want by setting the viewport display to Shaded or Rendered and the ‘buildings’ to use ‘Arctic’ -
Hmm, I don’t think that my intention is clear yet.
In architectural representation, we want to be able to use the arctic view, not the shaded view. For a nice visual reading of the shapes, it’s really important that the ambient occlusion shadows are visible. If I were to visualize it without the analysis mesh with sunlight hours, it would look like this, notice how there is a shadow on the ground at all of these edges where the buildings meet the ground. This shadow is really important visually, it establishes the ground plane.
If I change the mode to shaded, and then set all of the objects to Arctic using SetObjectDisplayMode, I receive something similar to what you posted. There is no ambient occlusion shadow and the shapes all appear extremely flat (this is difficult to read and extremely dated as a visualization technique. It makes the graphics look like they are 15 years old and that’s not acceptable for our office’s design documentation).
I want for the buildings and urban context to display with ambient occlusion based shading / Arctic mode WHILE displaying only the mesh using vertex colors.
I also do NOT WANT the ambient occlusion to apply to the mesh, because this will distort (likely darken) the colors on the mesh vertexes. That is also a deal-breaker because it means that the colors will not match the colors defined in our color legends.
I also want to emphasize that this worked in Rhino 6. If you still aren’t clear on what I mean, perhaps it is easier to speak by phone. Send me an e-mail to alexanderj@big.dk to set that up. I’m happy to help get this resolved however I can!
Hi Alexander - default Arctic in V6 to do what you want, and in V7, default Arctic, using ambient occlusion as the lighting mode, breaks the vertex colot display on the mesh - is that it in a nutshell?
Has this been solved? Because I’m also in architecture and I want to do the same thing but can’t figure out how. I want to set all objects in the scene to Arctic mode but I want a single mesh (imported from Ladybug,Honeybee, Gismo etc…) that has multiple colors assigned to the mesh itself to be set to shaded or rendered mode so that the multiple colors on the mesh are visible when everything else is white. Right now, if you go to arctic mode for the scene and then do setobjectdisplaymode on a multi colored mesh, the mesh just stays white.
Used flat shading and color the object green for example, and then use that to create a mask so that you can combine a capture of the display mode without arctic (ie perfect mesh colors) with a capture of the display mode with Arctic(nice shadows, but no colored meshes). You can create the masks in Photoshop by selecting by color or you might be able to do it with your rendering agent if you turn on some thing like material IDs when specifying which layers are exported from the render.
create a grasshopper script that uses the dot to display colored markers on each mesh face.
I’m also experiencing this issue. I see now that there is a check box option under the artic display mode settings for “Shade Vertex Colors” but it doesn’t seem to do anything.
It seems so simple. Use ambient occlusion AND display mesh colours. Like others have said it worked in Rhino 6, why not 7 or 8??
Has anyone solved this or found a work around that doesn’t require post processing or downgrading?
Just for comparison, here is the same view with Ambient Occlusion. The ability to display colored meshes with AmbientOcclusion changed functionality (broke ) between Rhino 6 and Rhino 7… this solution will require a bit more work from your graphics card but it should do the trick.
Change it from ‘Ambient Occlusion’ to ‘Scene Lighting’, set a single color for all objects (if you want all objects to be white). I prefer to un-check Shade vertex colors because that muddies the colors defined on the mesh.
