Rhino 7.8.21196.05002, 2021-07-15 crashing, Grasshopper not loading
Grasshopper crashes on start indicating external file load error. Unfortunately no information regarding the missing / corrupted file available
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05002, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Kommerziell, Build 2021-07-15
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H1217) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro13,3
Language: de-CH (MacOS default)
AMD Radeon Pro 460 OpenGL Engine (OpenGL ver:4.1 ATI-3.10.21)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: AMD Radeon Pro 460
Displays: Farb-LCD (258dpi 2x), iMac (109dpi 1x)
Graphics processors
Intel HD Graphics 530 (1536 MB)
AMD Radeon Pro 460 (4 GB)
Color LCD (1680 x 1050)
iMac (2560 x 1440)
USB devices
Apple Inc.: Apple T1 Controller
Conexant: CONEXANT USB AUDIO
Realtek: USB 10/100/1000 LAN
VIA Labs, Inc. : USB3.0 Hub
3Dconnexion: CadMouse
Bluetooth devices
None
Third party kernel extensions
com.3dconnexion.driver (1.1.4) 1DD89656-D184-33C7-B591-74B28B80D03F
com.kairos.driver.DuetDisplay (1) 0A9F5387-316E-3D61-B9ED-D066346F8797
com.intel.kext.intelhaxm (7.3.2) 58DFBE80-E54A-3EFE-B38A-215C5ED8E828
com.avast.FileShield (4.0.0) 70F76783-DAF2-3F4F-8B54-80F7253728FE
com.avast.PacketForwarder (2.1) E4859490-C479-314F-932E-7ABE0B99F7EC
com.parallels.kext.hypervisor (16.5.0 49183) 48004ADB-B3FF-30FF-9EF4-462AF5C1AF07
com.parallels.kext.vnic (16.5.0 49183) 0E0700DB-AB14-3B9D-A0A0-0C9A5980FB75
com.parallels.kext.netbridge (16.5.0 49183) 352AF9F8-FEA8-3B64-8E9A-476B25BE066B
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftFoundation.dylib
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Iris.MacR5.rhp “Iris” 1.0.0.0
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ggRhinoIFC/2.1.31.0/ggRhinoIFC.rhp “ggRhinoIFC” 2.1.31.0
/Applications/Rhino 7_8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Squish.rhp “Ebnen” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs-Werkzeuge” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_X.rhp “X Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_X.rhp “X Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.8.21196.1002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.8.21196.5002
/Applications/Rhino 7_8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.8.21196.5002
