Rhino 7, Grasshopper, C# Crash
Hi
Since the last 3 WIP updates for Mac I’m getting a repeatable Rhino crash when I edit a GH C# script component. I sent in a crash report the first time it happened but still happening in 7.0.20245.12006, 2020-09-01 so thought it deserved a forum post.
I removed all plugins, restarted and I still get the crash.
Steps:
Open RH 7 WIP and open a new model
Open Grasshopper
Add a new script component to the canvas
Add a line of code to the script, say A = 1.0;
Run code and close script editor
Grasshopper Menu > Window > Click on X to close the window
Do you want to save the changes? Select ‘No’
Immediate Rhino crash
System info follows
jack
Rhino 7 SR0 2020-9-1 (Public Build, 7.0.20245.12006, Git hash:master @ 975dd0e311651d094f935c82afba850ee06c31a4)
License type: Commercial, build 2020-09-01
License details: Cloud Zoo
Expires on: 2020-10-16
Apple Intel 64-bit macOS Version 10.15.6 (Build 19G2021) (Physical RAM: 32Gb)
Mac Model Identifier: iMac18,3
Language: en-GB (MacOS default)
AMD Radeon Pro 580 OpenGL Engine (OpenGL ver:4.1 ATI-3.10.16)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8 GB
Graphics: Radeon Pro 580
Displays: iMac (217dpi 2x)
Graphics processors
Radeon Pro 580 (8 GB)
iMac (2560 x 1440)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
Broadcom: Magic Mouse 2
Broadcom: Magic Keyboard with Numeric Keypad
Third party kernel extensions
com.intego.netbarrier.kext.monitor (551) 6B35F836-4904-3C7F-BF68-E3463443008A
com.intego.netbarrier.kext.network (551) ED2189D4-26E4-3EA9-84B2-CC673CFBC877
com.intego.netbarrier.kext.process (551) 129E9EE2-F4A7-3540-B2B8-89F915E29E53
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20245.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20245.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20245.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20245.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20245.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20245.12006
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20245.12006
