I have a 2017 MacBook Pro and have recently updated from macOS 10.14 to macOS 11.2. Since then, I can no longer use Grasshopper. Is it a known bug and do I have to downgrade or is there a workaround ?
I can launch Grasshopper but I cannot add any component to the canvas without Rhino crashing…
Thanks !
Best,
Félix
wim
(Wim Dekeyser)
March 11, 2021, 10:23am
2
Hi Félix - please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim, thanks for your answer, here is the result of SystemInfo.txt (5.7 KB) command :
Rhino 7 SR4 2021-3-10 (Rhino 7, 7.4.21069.13332, Git hash:master @ ccae1fd90d6c89471214a11230dcb924a2d1ed87)
License type: Educational, build 2021-03-10
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.2.2 (Build 20D80) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro14,3
Language: en
AMD Radeon Pro 560 OpenGL Engine (OpenGL ver:4.1 ATI-4.2.15)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 560
Displays: Color LCD (295dpi 2x)
Graphics processors
Intel HD Graphics 630 (1536 MB)
Radeon Pro 560 (4 GB)
Color LCD (1920 x 1200)
USB devices
Apple Inc.: Apple T1 Controller
Bluetooth devices
None
Third party kernel extensions
com.epson.driver.EPSONProjectorMPPAudio (1.40) CD50A087-0252-8C0B-7F9F-682E32D8A99E
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Users/felixchameroy/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/libtbb.dylib
/Users/felixchameroy/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/libtbbmalloc.dylib
/Users/felixchameroy/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/IntelDenoiser.Mac.rhp "IntelDenoiser.Mac" 1.0.0.0
/Applications/Rhino7.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 7.4.21069.1002
/Applications/Rhino7.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 7.4.21069.1002
/Applications/Rhino7.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 7.4.21069.1002
/Applications/Rhino7.app/Contents/PlugIns/Displacement.rhp "Displacement" 7.4.21069.1002
/Applications/Rhino7.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 7.4.21069.1002
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp "Import_OBJ" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp "export_xaml" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp "export_OBJ" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp "Export_DAE" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp "IGES Export Plug-in" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp "Import_SVG" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp "Export_AMF" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp "Import_DST" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp "PLY - Polygon File Format Export" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp "Import_AMF" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 7.4.21069.13332
/Applications/Rhino7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 7.4.21069.13332
Best,
Félix
wim
(Wim Dekeyser)
March 11, 2021, 1:46pm
4
Hi Félix -
Thanks for that - nothing that strikes me in that one.
Does this happen with any of the components that you place on the canvas or only specific ones?
I’m not seeing any crash reports from your eMail address. Are you sending in those reports?
Well I didn’t send all of them, but yeah quite a few.
For now, I haven’t been able to put a single component - tried with the simplest ones, params like Point , Curve , or Surface , or constructor ones like XYZ Point , Line 2Pt .
Hi @wim , I have no idea what weird was inside my Application Support folder, but I wanted to make a clean install of rhino and deleted it before reinstalling rhino, and now everything works back fine.
If it can be of use, the tiles of the starting screen of GH were showing a weird regular-Times-New-Roman-like font, instead of the usual bold-Arial-like font.
Thanks for your help.
Best,
Félix
Valeria3
(Valeria)
January 25, 2022, 6:54pm
7
Hello I have the same problem, is there a solution? I cannot use GH in my Mac.
