Installation Error rhino.msi : -2147023293
Good Evening
My rhino ran into a problem and it did not open the program anyway. I uninstalled it and removed every single trace of it in the registries. now it doesn’t install any version of rhino 7 it says "newer version is installed " error code: rhino.msi : -2147023293 I even tried installing rhino 8 wip but still the same error would you please help with this I’m truly in need of it and now I’m stuck.
log files has been attached
Rhino_7_20221201223612.txt (69.9 KB)
Regards
Hani
The log indicated a -1603 error
https://wiki.mcneel.com/rhino/6/install/error/1603
this might be helpful as well
https://wiki.mcneel.com/rhino/uninstalling
Hello sir thank you for your reply
I’ve had tried them none of them worked
Please recheck that you have installed all windows updates, the .Net update & then the repair tool, removed all the keys and have ran the Microsoft’s Uninstall Fix.
