When I initiate Rhino 6 from the taskbar icon, the new window does not combine with the existing taskbar icon. I cannot believe that after the numerous iterations this program has gone through that such a simple error would be overlooked. Can McNeel provide a solution/update for this error or provide a helpful fix for the problem?
Hello - presumably you have Windows set to combine the icons, correct?
As far as I know this works as expected.
Hello - can you please run the SystemInfo command in Rhino and post the results here?
Pascal,
Rhino 6 SR17 2019-8-23 (Rhino 6, 6.17.19235.15041, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Commercial, build 2019-08-23
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: HANSEN
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 3-16-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 391.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-16-2018
Driver Version: 23.21.13.9125
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.17.19235.15041
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 6\Plug-ins\BlockEdit.rhp “BlockEdit” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp “Named Position”
C:\Program Files\Rhino 6\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
Hello - just in case, please disable VRay in Options > Plug-ins and then restart Rhino. I don’t know why it would make a difference either, but we’ve seen some peculiar effects from plug-ins, so I’d like to at least see what happens.
Any different?
Hi Pascal,
The disabling of VRay does not change the taskbar icon performance. The icon continues to duplicate itself and not combine with the pinned icon. Thoughts?
Hi Pascal,
Please, disregard the previous comment. The disabling of VRay did fix the issue with the pinned taskbar icon. What does this mean?
Hi Emanuel - that means that this is something that VRay is somehow influencing. We have no control over that and you’ll want to contact VRay support on this matter.
