Rhino 6 SR27 Release Candidate 1 for Windows and Mac (6.27.20147) is now available
Bugs Fixed:
- Join: Joining meshes with ngons duplicates meshes (RH-58431)
- Licensing: Cloud Zoo: Spelling error when there are no licenses on a Team (RH-58296)
- Localization: Linetype name localization inconsistent in French version (RH-58181)
- OpenNURBS: Unable to read Leader.PlainText from Rhino3dmIO and openNURBS (RH-58606)
- Rendering: Materials: Rendering Materials: RenderContent.OpenInEditor() does not work correctly for child textures (RH-58438)
- SDK: RhinoCommon:
Regressions Fixed:
- SelLayer: Sellayer: Wildcards does not work with sub-layer names in script (RH-58633)
Mac-Only Changes
Bugs Fixed:
- Annotation: Text: Annotation Text: Scroll through text in Properties (RH-56660)
- File IO: Export layout to PDF - Page orientation (RH-58099)
- Gumball: Clicking Extrude ball shows wrong prompt - cosmetic (RH-58542)
- Named Position: Closing a file with NamePositions, then Quitting and restarting Mac Rhino deletes the saved named positions in the file (RH-58609)
Incomplete Port:
- File IO: PDF Export - When exporting a layout to PDF, "Viewport" should say "Layout" (RH-58102)
UI Change:
- LayoutWorkspace: Layouts: Number layouts in the left-hand sidebar (RH-57543)
Windows-Only Changes
Crashes Fixed:
