Rhino 6 SR27 (6.27.20176) is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Rhino.UI csproj is missing *.png resource inclusions (RH-58962)
- Display: Clipping Edges Missing for Blocks (RH-58732)
- Eto: FontDialog FontChanged event doesn't fire (RH-58002)
- Join: Joining meshes with ngons duplicates meshes (RH-58431)
- Licensing: Cloud Zoo: Spelling error when there are no licenses on a Team (RH-58296)
- Localization: Linetype name localization inconsistent in French version (RH-58181)
- OpenNURBS: Unable to read Leader.PlainText from Rhino3dmIO and openNURBS (RH-58606)
- Options: Files read-only if file locking is off (RH-59194)
- Rendering: Materials: Rendering Materials: RenderContent.OpenInEditor() does not work correctly for child textures (RH-58438)
- SDK: RhinoCommon:
Regressions Fixed:
- Make2D: Doesn't recombine lines properly (RH-57426)
- SelLayer: Sellayer: Wildcards does not work with sub-layer names in script (RH-58633)
Mac-Only Changes
Bugs Fixed:
- Annotation: Text: Annotation Text: Scroll through text in Properties (RH-56660)
- File IO:
- Gumball: Clicking Extrude ball shows wrong prompt - cosmetic (RH-58542)
- Named Position: Closing a file with NamePositions, then Quitting and restarting Mac Rhino deletes the saved named positions in the file (RH-58609)
Crashes Fixed:
- Properties: com.mcneel.rhinoceros.RhCore:-[MRObjectPropertiesBasicSection runScript:] (RH-59126)
Incomplete Port:
- File IO: PDF Export - When exporting a layout to PDF, "Viewport" should say "Layout" (RH-58102)
UI Change:
- LayoutWorkspace: Layouts: Number layouts in the left-hand sidebar (RH-57543)
Windows-Only Changes
Bugs Fixed:
- Display: Stuttering viewport rotation (RH-58680)
Crashes Fixed:
- ntdll!RtlpWaitOnCriticalSection – Access Denied (RH-56455)
- Eto: ReduceMesh command - System.NullReferenceException: Eto.Wpf.Forms.Controls.NumericStepperHandler.HandleFocus (Object sender, RoutedEventArgs e) (RH-58281)
Usability Problems Fixed:
- File IO: Read-only state is not respected after first Rhino instance exited (RH-58666)
