Rhino 6 SR11 (6.11.18344) Is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Crashes Fixed:
- Eto: System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto. (RH-48315)
- FilletEdge: ntdll!RtlFreeHeap – Access Denied (RH-48935)
- MakeHole: opennurbs!ON_Brep::Duplicate – Access Denied (RH-48812)
- No Subsystem:
- OpenNURBS: ON_TextRunPool::GetManagedTextRun() sometimes returns the address of ON_Font::Default (RH-49375)
- Rendering: Materials: Crash on layer material (RH-48865)
- RoundHole: opennurbs!ON_Brep::Duplicate – Access Denied (RH-48771)
Features Added:
- Grasshopper: Components: Polygon from edge (RH-48894)
Regressions Fixed:
- Annotation: Hatch: Scaling an hatch shouldn’t change pattern scale (RH-48448)
Enhancements:
- Grasshopper: Curve Division must be smarter to take into account the end of the curve and rounding errors. (RH-49039)
Bugs Fixed:
- Annotation:
- Annotation: Leader: History updates when detail activated (RH-49029)
- Annotation: Text: Can’t create Text (RH-48817)
- ApplyDisplacement: Transform mesh with displacement (RH-43929)
- ApplyShutLining:
- ClippingPlane: Can’t access material in Clippingplane proprteis (RH-48871)
- ContinueCurve: Continue a rational curve (RH-48989)
- Display:
- Custom IsFrontFacing function breaks down when object is far from origin (RH-49748)
- Dimensions disappear (RH-49049)
- Front face color gone on selection (RH-47383)
- Lines and text disappear (RH-49547)
- Meshing preview for shaded modes (RH-13288)
- Purge GL21_TextGlyphy.shader and GL33_TextGlyph.shader from all Rhino 6.x source (RH-48839)
- Wide thin viewport shows envsphere in Rendered mode (RH-44677)
- ExtendSrf: Ignores some edges (RH-46098)
- ExtractMeshPart: Selection switches on and off randomly (RH-48829)
- File IO:
- FilletEdge: Edit option leaves handles visible for already selected edges (RH-48875)
- Grasshopper:
- Grasshopper: Components: Line charge broken if x=0 (RH-49083)
- Gumball: Turn back on the bunny tail menu ball on by default (RH-48909)
- Licensing: UI:
- Licensing: Validation:
- Localization:
- Loft: Loose option should use a better parameterization (RH-49231)
- Make2D:
- Mesh: The mesher does not work right with surf… (RH-292)
- Mirror: Flips normals inward (RH-49075)
- No Subsystem:
- ControlGridLayout create a method to freeze layout while adding controls (RH-49192)
- ControlGridLayout tune up for center aligned controls (RH-49186)
- Make NumericSteppers in Rhino.Ui.Controls public (RH-48879)
- Multidoc support fixes in Lasso et al (RH-49016)
- Sizing error crash in WpfElementHostBase in RhinoWindows.dll when loading large document text collection (RH-48656)
- Undo does not work properly in sub-node controls (RH-48890)
- OpenNURBS:
- PluginManager: Rhino says Faro Digitizer plugin needs to be updated, but provides little information on what to do. (RH-48160)
- Properties: No content control context menu (RH-48172)
- Pull: Pullback should be in surface domain (RH-49147)
- Purge: Report is misleading (RH-48518)
- RDK:
- ReduceMesh: Fast Accurate option is missing from Reduce Mesh dialog (RH-47746)
- Editing material parameters on huge models is slow (RH-48750)
- Material changes when we Insert a Block (RH-48341)
- Multiple materials get created when dragging a box (RH-44925)
- Per face material in wireframe temporarily breaks shaded modes (RH-47892)
- Properties match is slow, adds many materials (RH-48670)
- Texture mapping doesn’t update in the display when changing units (RH-48945)
- Rendering: Realtime SDK: VArq issues (RH-48278)
- Rendering: Texture Mapping: Custom object texture mapping: Inconsistency in Rendered display mode (RH-46497)
- SDK: Add Euler angle support in ON_Xform (RH-49074)
- SDK: RhinoCommon:
- :Transpose to RhinoCommon (RH-49013)
- Add view: no anti-aliasing and performance hit (RH-49159)
- ArchivableDictionary missing GetPlane and/or TryGetPlane method (RH-49203)
- InstanceDefinition wrapper causes access violation / crash (RH-49605)
- TextEntity.GetBoundingBox() returns incorrect (RH-48756)
- Undo Python and layer (RH-45947)
- SDK: RhinoScript: Importing multiple display mode configurations crashes Rhino (RH-49421)
- SelConnected: Wrap around closed curve & surface seams (RH-49156)
- SubD: Micro gaps in SubD meshes (RH-49094)
- Text: Troubles with Text (RH-49154)
- TextObject: Elaborate about AllowSingleStroke option in the help (RH-48437)
- Tutorials: Sorts all items (RH-49653)
- UnrollSrf:
Usability Problems Fixed:
