hello, I have by default inch on paper = meter in model in the Print setup, I was wandering if is possible to set mm or cm as default
Hello - this follows the model units by default, I do not see anyway to change this.
I must admit that I get confused by this and should probably check some more but the last time I did that, I concluded that the Scale - On Paper setting was something that was remembered between sessions - RH-38875.
Making a template with a particular scale, the actual distance is remembered correctly in the file but it reverts to model units - thus setting 1mm results in the template in .001 meters in a meters file when opened - sort of a hybrid…
thanks, will try
