Rhino PDF custom size bug
Hi everyone,
When i print a pdf using rhino pdf i always have to change from inch to mm without measurement conversion, so i always have to restore the custom size.
This i not a big deal if you create a pdf a week, but is so annoying when i need to print a many of pdf a day.
Is this issue fixeble in any way on rhino7??
Hello- I’m not sure what you mean here exactly - can you give a blow by blow?
Hi Pascal, I am not sure what @samuelef1992 means but I always get my units in cm when printing from a custom size. Not sure if bug or not but not ideal.
No matter the units of my model or my layout:
Start new document:
Create layout with custom size (lets do 50 by 50)
Print and I get this:
Change unit from window to back inches and I get this: (no conversion)
Even when I input everything correctly and print:
Print again and my window is back like this:
The same happens when printing to image. And for some reason it also does not remember that I printed to image and default back to Rhino PDF.
Hi and sorry for may late reply.
My issue is almost the same that @ShynnSup desrcibe.
  1. I set Rhino PDF size from inch to millimetres
    Rhino PDF_1
  2. Now if for some reason i cloese print window PDF size is back to inch and Rhino convert the measures
    Rhino PDF_2
  3. After reopen print window I need to set PDF units back to millimetres but this time Rhino does NOT convert measures and scale my document preview, i must reset PDF size manually like 1.step.
    Rhino PDF_3
I think rhino pdf default units should be the same as document settings.
!!Quick update!!
This issue have been fix on the last release.
Thank you, Samuele.
