Hi
I have an issue since the end of February some time with not being able to print full shadows and shading in rendered view from layouts from my desktop. The shading appears on the screen and on print preview but does not print/save as PDF which comes out as cartoonish - there are some shadows but not on solid faces (I can’t really identify what exactly is missing - ambient?).
I have checked back and this was fine up till at least 25/02/22. I upgraded to Windows 11 at the beginning of the year so this can’t be the issue. The shadows still pdf correctly on my laptop running Windows 10. I have exported an ini file for rendered from the laptop an installed it on the desktop but this does not help.
I have updated the driver for the NVIDIA GPU and the Intel integral graphics card which as had no effect. I have repaired the installation of Rhino to no effect.
I have spent hours changing settings to try an produce shading and contrast in the views but comparing with previous exports it is clear that something is not printing no matter what is set up.
Can anyone identify what has happened and how to fix it please?
Thanks very much.
Regards
Ian
Sysinfo below:
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo. In use by: ianjlove ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-7U1KEPV
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
Secondary graphics devices.
NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 4-20-2022 (M-D-Y).
> Accelerated graphics device with 1 adapter port(s)
- There are no monitors attached to this device!
ATTENTION:
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
- Recommended: Unplug the monitor and plug it into one of the video ports on this device:
[NVIDIA GeForce GTX 1050]
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9664
Driver Date: 6-1-2021
Driver Version: 27.20.100.9664
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\export_PDF.rhp “PDF Export” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
System Specs are as follows:
| Device name | DESKTOP-7U1KEPV |
| Processor | Intel(R) Core™ i7-8700T CPU @ 2.40GHz 2.40 GHz |
| Installed RAM | 16.0 GB (15.8 GB usable) |
| Device ID | 07F14C08-0C0A-4C49-9276-BE41E29B4F2A |
| Product ID | 00325-81228-74147-AAOEM |
| System type | 64-bit operating system, x64-based processor |
| Pen and touch | Touch support with 10 touch points |
| Edition | Windows 11 Home |
| Version | 21H2 |
| Installed on | 17/01/2022 |
| OS build | 22000.739 |
| Experience | Windows Feature Experience Pack 1000.22000.739.0 |
