Recently I noticed that all layouts had activated unwanted layers. Not knowing what had caused the problem, I reverted to a recent copy of the model. It has happened again, and I now know the trigger. I made a minor change to the model, and wanted to print some of the layout pages. Normally, I would save the model, then activate all layers in any of the 4 working views, then print the required layout pages, then close the model without saving so that only the working layers are active. The problem arose when I forgot the save step. In order to save the minor changes without all layers being active, I used Ctrl Z to undo the activation of all layers, then saved, then reactivated all layers. At that stage, all layouts had unwanted layers active.
On the matter of layouts, something that is annoying is that when a new layer is created, it becomes active in all layouts. That requires manual adjustment of every layout. Is there a setting to override this behaviour?
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo. In use by: Garry Nelson ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: LIGHTNING
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2080 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 6-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 532.09
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-2-2023
Driver Version: 31.0.15.3209
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
Correct layout example…
Corrupted layout example…
Regards, Garry.
