I’m getting bad lag when rotating, specifically in 2 cases:
- Rotating “through” the viewport grid.
See screen shot below. The grid gets all jagged as I approach it and then the rotation motion lags. This happens regardless of scene geometry, even with an empty file. I generally work with the grid turned off, but the lag happens either way, so I took the screen shot with the grid on since I believe the jagged lines are a related symptom. - Rotating “through” geometry.
Imagine a pair of glasses. If I’m zoomed in on the front of the nose bridge and rotate around to the back of the bridge the viewport travels “through” the lens or other frame geometry, and lags for a few seconds at a time.
I’ve tried zoom>target without any change.
System info:
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Commercial, build 2021-02-03
License details: Stand-Alone
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: HP
Primary display: Intel(R) HD Graphics 620 (Intel) Memory: 1GB, Driver date: 10-17-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce 940MX (NVidia) Memory: 2GB, Driver date: 6-9-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.80
> Integrated acclerated graphics device (shares primary device ports)
Secondary graphics devices.
DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 4-16-2020 (M-D-Y).
> External USB display device with 3 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-9-2021
Driver Version: 27.21.14.6280
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
