Poor Viewport and navigation performance
I have recently had a PC built specifically to run Rhino and I am experiencing extremely laggy viewport navigation on all shading types. I am currently running a trial version of Rhino 7 as I wanted to test it out before making the decision to upgrade from Rhino 6. I should add all files I am opening are Rhino 6. I hope someone can help me.
PC Specs,
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Evaluation, build 2021-06-09
License details: Cloud Zoo
Expires on: 2021-10-10
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 6-21-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.11
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 2.1
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-21-2021
Driver Version: 30.0.14.7111
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21160.5001
Looks like you’ve been playing with the OpenGL level support. Right now you’ve configured Rhino to use only OpenGL 2.1, which most likely is causing the poor performance.
You may want to reset it back all the way to the right: Tools > Options > Views > OpenGL. Set the slider all the way to the right for max supported OpenGL level. Then restart Rhino and see if that is any better.
Fixed! Thank you Nathan. I don’t remember touching this setting but that has 100% done the trick.
