Rhino 6 SR17 (6.17.19235) Is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
- Annotation: Text: CRhinoDoc_AddText ignores bold (RH-53086)
- BoxEdit: Incorrect size info (RH-53923)
- Build Process: Rhino3dm (iOS): Consider adding a reference to System.Drawing.Common (RH-54050)
- Choose One Object: “All” option in selection menu and subobjects (RH-53290)
- Display:
- Draw ground plane intersections with shader (RH-53855)
- Edges cannot be turned off (RH-54193)
- Panning broken in details (RH-53540)
- Points disappear (RH-44417)
- Receive shadows is ignored in the viewport (RH-50641)
- The “Flat shading” setting in ANY display mode doesn’t seem to stick when changed (RH-50741)
- Documentation: Document ability to override settings by sys admins (RH-53059)
- File IO:
- FilletEdge: FilletEdge fails, OK in V5 (RH-52388)
- Offset: Offset breaks up (RH-53398)
- PackageManager: PackageManager has access to Internet when DisableInternetAccess=1 (RH-54087)
- Pipe: Preselecting open and closed curves and using a Cap option results in extra surfaces (RH-53455)
- Print:
- RDK:
- Rendering: Realtime SDK: Moving clipping plane incorrectly triggers ApplyMeshChanges (RH-53225)
- SDK: Cannot subobject pick extrusions from an instance object using GetObject (RH-53460)
- SelBrush: SelBrush does not work as transparent selection command from Move (RH-52604)
- Selection: Backface color transparency affects selection (RH-53491)
- SelectionFilter: Filter and widgets (RH-53483)
- Shear: Macro with Shear command fails when drag-selecting (RH-53192)
- ShowEdges: ShowEdges dialog problem (RH-53151)
- Sweep1:
- WebBrowser: Too old to work on a website (RH-53549)
Crashes Fixed:
- Annotation: Text: Crash with this font (RH-49785)
- Drag: RhinoCore!CRhinoObject::IsHidden – Access Denied (RH-53292)
- Eto:
- No Subsystem:
- 0x00000057
1c8fc780!0x00000057
1c8fc780 – (NTSTATUS) 0xe0434352 - (RH-50800) - 0x1!0x1 – (NTSTATUS) 0xe0434352 - (RH-53031)
- Could not find HatchPattern with ID ec0fc635-4c6a-40b6-9679-8fcbf56528a6 (RH-53580)
- Method not found: ‘Void Rhino.Render.CustomRenderContentAttribute…ctor(System.String, Boolean, System.String, Boolean, Boolean, Boolean)’. (RH-53844)
- 0x00000057
- Options: Searching Options > Advanced crashes Rhino (RH-53306)
- Toolbar: NullReferenceException: UnsafeNativeMethods.CRhinoUiToolBarManager_OnToolBarButtonClicked (RH-53598)
- WeldVertices: opennurbs!ON_DotProduct – Access Denied (RH-54055)
Enhancements:
- Display: Technical Display Performance Improvements (RH-54123)
Meta Issue:
- SDK: Python: Add a note to the RhinoScriptSyntax README to help contributors understand our branching scheme (RH-53346)
Performance Improvements:
- Display:
Regressions Fixed:
- Display:
- No Subsystem: Correct typefaces not always found for certain languages (RH-53897)
- Sweep1: Untrimmed miter error (RH-52961)
SDK Enhancement:
- SDK: RhinoCommon: Provide support for enforcing Raster output in ViewCaptureSettings (RH-52318)
