Raytraced display mode hangs up Rhino 6.3. It did not happen in Rhino 6.1
Any specific steps you do to get it to hang? I’ve been using 6.3.18090.471 since it was released daily without any hangs.
No specific steps. This is the 3DM file which caused the crash twice: junkR6-1.3dm (857.5 KB)
This is the crash file: RhinoDotNetCrash.txt (1.1 KB)
I cannot upload the dump file (RhinoCrashDump.dmp).
If you got a dmp file, please upload it at www.rhino3d.com/upload and use nathan@mcneel.com as recipient.
Thank you.
I have just uploaded the dump file. (First upload is empty.)
Thank you, investigating now.
@Andrew_Nowicki, the crashdump contains good information, but it’d be useful to know what you where doing when the file caused a crash. Just opening and switching to Raytraced doesn’t crash, but no doubt some action did. If you could recall your steps leading up to any of the two crashes.
[quote=“nathanletwory, post:6, topic:60387”]
It does crash. System info:
Rhino 6 SR3 2018-3-31 (Rhino 6, 6.3.18090.471, Git hash:master @ b32d93f452fce970e96deb46bfc68b075f06b290)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Quadro K2000M/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 391.03)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-27-2018
Driver Version: 23.21.13.9103
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18018.1000\5.5\Legacy\Flamingo.Legacy.dll "Flamingo nXt Legacy File Reader "
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Bongo 2.0 (64-bit)\BongoUI.20.v60.rhp “BongoUI20v60”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18053.1000\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5”
I have updated NVIDIA driver from 391.03 to 391.33. It did not help - Rhino 6.3 crashes as soon as I switch display mode to Raytraced.
I have a change for code ready that at least works around the potential crash - I’d still like to know better steps to reproduce. Just changing to Raytraced doesn’t crash for me. Do you have any non-default Raytraced and Cycles settings? Please go to Tools > Options > Advanced, typeRhinoCyclesin the filter and selectOnly display modified values`. Please post a screencapture of any modified values.
I’ll try tomorrow reproducing the crash without my patch.
I unfortunately still don’t know how the code gets into this situation, but I can ensure at least no crash happens.
If I change the RhinoCycles.SelectedDeviceStr to its default value, the Raytraced mode also crashes Rhino.
This particular crash is fixed in the upcoming 6.4
Hello, same problem and I’ve installed:
Versione 6 SR5
(6.5.18132.5131, 12/05/2018)
Also, when 2D drawing a curve, I see the preview but when I end the command everything disappears. Ctrl+A selects the curves but I can’t see them.
The .txt file named “RhinoDotNetCrash” reports:
System::Windows::Forms::Application::ThreadException event occurred
SENDER: System.Threading.Thread
EXCEPTION: System.Runtime.InteropServices.ExternalException
MESSAGE: Errore generico in GDI+.
SOURCE: “System.Drawing”
CALL STACK
in System.Drawing.Graphics.MeasureString(String text, Font font, SizeF layoutArea, StringFormat stringFormat)
in System.Windows.Forms.Label.GetPreferredSizeCore(Size proposedConstraints)
in System.Windows.Forms.Control.GetPreferredSize(Size proposedSize)
in System.Windows.Forms.Label.GetPreferredSize(Size proposedSize)
in System.Windows.Forms.Layout.TableLayout.InflateColumns(ContainerInfo containerInfo, Size proposedConstraints, Boolean measureOnly)
in System.Windows.Forms.Layout.TableLayout.ApplyStyles(ContainerInfo containerInfo, Size proposedConstraints, Boolean measureOnly)
in System.Windows.Forms.Layout.TableLayout.LayoutCore(IArrangedElement container, LayoutEventArgs args)
in System.Windows.Forms.Layout.LayoutEngine.Layout(Object container, LayoutEventArgs layoutEventArgs)
in System.Windows.Forms.Control.OnLayout(LayoutEventArgs levent)
in System.Windows.Forms.TableLayoutPanel.OnLayout(LayoutEventArgs levent)
in System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args)
in System.Windows.Forms.Control.PerformLayout()
in System.Windows.Forms.Control.ResumeLayout(Boolean performLayout)
in System.Windows.Forms.Layout.LayoutTransaction.Dispose()
in System.Windows.Forms.Label.OnTextChanged(EventArgs e)
in System.Windows.Forms.Control.set_Text(String value)
in RhinoWindows.WindowsLocalization.LocalizationStringTable.LocalizeControlTree(String formName, String formClassName, Control ctrl, ToolTip[] tooltips)
in RhinoWindows.WindowsLocalization.LocalizationUtils.LocalizeForm(Assembly assembly, Int32 languageId, Control form)
in RhinoSplash.LicensePanel.Init()
in System.Windows.Forms.UserControl.OnLoad(EventArgs e)
in System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
in System.Windows.Forms.Control.CreateControl()
in System.Windows.Forms.Control.SetVisibleCore(Boolean value)
in RhinoSplash.Splash.TabActivated(Object sender, TabActivatedEventArgs e)
in System.EventHandler`1.Invoke(Object sender, TEventArgs e)
in RhinoSplash.TabPanel.set_ActiveTab(Tabs value)
in RhinoSplash.Splash.Splash_Load(Object sender, EventArgs e)
in System.Windows.Forms.Form.OnLoad(EventArgs e)
in System.Windows.Forms.Form.OnCreateControl()
in System.Windows.Forms.Control.WmShowWindow(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.Form.WmShowWindow(Message& m)
in RhinoSplash.Splash.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Are you sure you are using Raytraced when the crash happens?
Ok, I solved the 2D drawing problem by clicking on Options>View>OpenGL page and un-checking the setting for GPU tessellation as suggested in:
But still, the program crashes immediately using Raytraced display mode. Yes Nathan, I’m sure:
I think it could be related to the video card drivers, but the last time I upgraded my Nvidia I had several computer crushes with blue screen, so I went back before the update… It has to be here the issue
@u_d_00 Please paste the results of Help\Rightarrow System\;Information.
Rhino 6 SR5 2018-5-12 (Rhino 6, 6.5.18132.5131, Git hash:master @ b8b8945d46018b7f175f54f1e384ede46df9745d)
Licence type: Evaluation, build 2018-05-12
License details: Stand-Alone
Expires on: 2018-08-11
Windows 8.1 (Physical RAM: 16Gb)
Machine name: PC-UTENTE
GeForce GTX 860M/PCIe/SSE2 (OpenGL ver:4.4.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.4
Shading Language: 4.40 NVIDIA via Cg compiler
Driver Date: 9-16-2014
Driver Version: 9.18.13.3360
Total Video Memory: 4 GB
