You should try updating your drivers again. These are pretty old, and the newer ones work much better.
But before you do that you might want try the following few things
- Go to Tools \Rightarrow Options \rightarrow Cycles and click the button to reset to default settings. Try
Raytraced
. If this works you can skip the rest, - Go to the same options page, but now set CPU as your render device. If this works you can skip the rest
- Go to Tools \Rightarrow Options \rightarrow Advanced. Type
UseDrawOpenGl
in the filter field. Uncheck the option.
Let me know if any of these worked.
