Hi Everyone,
For some reason, my Rhino 8 trial version crashes whenever I select the Raytraced display mode, causing my PC to restart. All of the other display modes work fine. Below is a screenshot of the OpenGL settings under Tools/Options/View within Rhino 8:
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A6000 (NVidia) Memory: 48GB, Driver date: 10-18-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.70
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-18-2023
Driver Version: 31.0.15.3770
Z-Buffer depth: 24 bits
Total Video Memory: 49140 MB
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\23.4.0.0\bella_rhino.rhp “Bella” 23.4.0.0
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
Indeed you need drivers from this year, old as yours tend to crash Rhino. The crash happens somewhere in Windows libraries, but it takes apparently Rhino down too.
The latest for your RTX A6000 is Driver Details | NVIDIA. When you start do a custom/advanced installation and make sure you check the Clean Installation box.
I know for a fact Rhino works with the RTX A6000. I use one as well.
Anyway, your issues is different @jmcauley , since your machine doesn’t reboot on switching to Raytraced.
As far as the PSU goes, I think I’m pretty much stuck with the 300W power brick that came with my midi workstation. Luckily, I can run Maverick Render fine from within Rhino, so it’s not a total loss. Thanks for your help.
So far the only suitable alternative I’ve been able to find is the SlimQ Gaming Laptop power charger rated at 500W (20V/25A), but it hasn’t been released yet, as it is still under development.
