Rhino 8 crashing in Materials Panel
Multiple issues with Materials Panel crashing my Rhino8. Happened both before and after most recent update, and seems regardless of file.
Some crashes, tho haven’t had the time to test how consistent:
  • Searching for a material name
  • Opening/closing a material
  • Selecting option for Floating material window
  • Slider adjustments
Please let me know if you need the file I’m currently working on - I can upload it to the link (I shouldn’t upload this model to the general discourse.)
Thx
Alan
SysInfo
Rhino 8 SR9 2024-6-19 (Rhino 8, 8.9.24171.03001, Git hash:master @ c7bc7dce8c2b456b3f0c5f0fa669295aa802ef1a)
License type: Commercial, build 2024-06-19
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 6-1-2024 (M-D-Y).
- Secondary monitor attached to adapter port 0
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 1.1
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: Not supported
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Garage\8.7.24140\net7.0\Garage.rhp “Garage” 8.7.24140.15431
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
@Alan_Farkas - can you disable all plug-ins that do not ship with Rhino, and then try to repeat?
Also, I’m not seeing a crash report from you regarding this. Did you submit one?
Thanks,
– Dale
Hi @dale There was no crash report window, or I would have been happy to send it.
If there’s a way to find the crash somewhere on my system, I’d be happy to share.
Will have to try the plug-in thing.
Look on your desktop for a DotNet crash text file…
Yep, none. Maybe I changed some setting.
FYI - I tried disabling and then re-enabling plugins, and now seem s to be ok. :shrug:
Nope - crashed again (just before saving bunch of work :sweat_smile:
Same Problem Here - on my Mac
→ But I found the malefactor - In my Case the deactivation of the Maxwell Plugin helped.
(Before I complete cleaned the application support folder from Rhino - after the Maxwell reinstall the Problem were back).
hehe maybe it is time to switch to Bella :smiley:
(my Problems startet with the SRC-8.9.24177.13002, 2024-06-25
Btw, you shouldn’t use this material - it was intended to be a stop-gap PBR material for Rhino 6 only. Rhino 7 and Rhino 8 have a good Physically Based material that is properly integrated.
Should I disable the plugin, itself? Or is it just the material?
The material only provides a material, but it would be wise to disable the plug-in and replace all material assigments of that material to the physically based material in Rhino 7 or Rhino 8
