I’m having trouble getting dimension and text scaling to behave consistently in Rhino.
My goal is to add dimensions in model space and have them appear at the same visual size in layout space, regardless of the viewport scale (e.g. 1:50, 1:100, 1:200).
However, when I enable Layout Space / Annotation Scaling, the dimensions change their appearance when I switch between different layout scales. For example, dimensions look correct at 1:50, but the text and arrows appear different at 1:200.
In short:
Is it possible in Rhino to create dimensions in model space that maintain the same paper size in layout space across multiple viewport scales?
Or is the only correct workflow to place all dimensions directly in layout space?
I’m using Rhino 8 on Mac.
Any clarification on the correct workflow or limitations would be appreciated.
