RH8_ ArrayLinear _NO preview in X-Ray-model
The preview does not appear with the surfaces
Hello- as far as I can see the preview shows in all modes here.
In the upper section X-Ray
In the bottom section, Rendered
The preview does not appear in X-Ray
Hi @RedAlert - can you run the SystemInfo command and post the output?
– Dale
Rhino 8 SR1 2023-10-31 (Rhino 8, 8.1.23304.10001, Git hash:master @ 00849e0909dc3cc92c425309d4f87320a4ef203f)
License type: Evaluation, build 2023-10-31
License details: Cloud Zoo
Expires on: 2024-01-30
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 16GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\BlackWhiteSwitcher\0.1.0\BlackWhiteSwitcher.rhp “BlackWhiteSwitcher” 0.1.0.0
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoFileVersion\7.0.8486\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.8486.27751
C:\Program Files\Orang\Orang 3.0\Orang7.rhp “Orang”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23304.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23304.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23304.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23304.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23304.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23304.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23304.10001
Hi -
That appears to be a heavily modified display mode. X-Ray looks like this on my system:
What happens when you use the factory-default settings?
Have you tried disabling those plug-ins?
Indeed, if I disable edges in XRay I also see no ArrayLinear preview. The same would happen in V7 btw. With the difference that Isocurves are still visible
True, when Surface Edges is disabled, the preview does not appear.
