I’m told that Rhino 6 wip the preview of the “ArrayLinear” command is not displayed correctly (updated video drivers and shaded mode enabled). Display preview problem in perspective view
Also, an preview for the “ArrayCrv” command would be welcome.
Check you, please, maybe it’s a bug.
Yeah… the current scene is very small - just the one rectangle, I guess? , so the camera is clipped to that object and the preview does not count for the camera clipping. My guess is that if you first add a point or any other object to the scene on the other side of the rectangle this will not happen…? I don’t know if this counts as a bug or a limitation, but I’ll add it to the pile.
It does not happen in V5. =Bug… https://mcneel.myjetbrains.com/youtrack/issue/RH-39140
thanks,
RH-39140 is fixed in the latest WIP
