the behavior of the “text” or “Leader” command has changed after the last update.
Now is not possible to write text immediately - there is no cursor in the text edit window after end of command.
The user must first click into the text edit window in order to type text - why?
Hi -
I see that this was previously reported in the following thread:
https://discourse.mcneel.com/t/text-block-seems-to-have-changed-since-last-update-need-to-do-extra-click-into-the-box-first-to-write-text-how-to-i-stop-it-doing-this/
Can you run the Rhino SystemInfo command and copy-paste the result here? Also, do you know which version you were running before this one?
Yeah, i see.
I tried to search this problem in the forum but unsuccessfully…
Here is the SystemInfo result:
SystemInfo.txt (2.8 KB)
I always install the new version when it comes out - all release candidates.
I noticed this issue during the penultimate (previous this one).
Rhino 7 SR10 2021-8-11 (Rhino 7, 7.10.21223.07001, Git hash:master @ a594cb4449602d6cce40b57e3359213e6441c15f)
License type: Commercial, build 2021-08-11
License details: Cloud Zoo
Windows 10.0.18362 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K2000 (NVidia) Memory: 2GB, Driver date: 9-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.39
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-22-2020
Driver Version: 27.21.14.5239
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.3.7.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21223.7001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21223.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21223.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21223.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21223.7001
After latest update problem still persists…
7.10.21236.11001, 2021-08-24
Something new? Still persist…
Hi -
This should be fixed in 7.11 which currently is a release candidate that you can install - the YT report is here: RH-65370
Yes, greate! Thank you.
