after latest update 6.18.19266.14201, 23.09.2019 - it’s not possible to load image (“Picture”) to wireport via “drag and drop” princip…
Hmm, seems to be working here… however I’m on the 6.19 release candidate already…
(6.19.19267.15571, 24-Sep-19)
Hmmm,
after install RC 6.19 nothing change…
Hello - just to be sure, are you running Rhino at the same level of permissions as your log-in to Windows? Not, for example, using ‘Run as Administrator’? (This one may be different even if your log in is an admin)
when is Rhino running “As administrator” then is not possible to load image to - but other way - i see “stop” mark.(mouse in wireport)
But when Rhino running “usually” i see standard “plus” icon on mouse but the command will not start…
Hello - does any drag and drop work? (3dm files for example). And please run SystemInfo and post the results, I wonder if there’s a plug-in is getting its oar in somehow.
Hey Pascal - just an heads up to say there’s another user with the same issue. Drag’n’drop a PDF works fine, he says:
Hello Pascal,
i am sending system info. Drag and drop for example for PDF or 3dm is ok…
SystemInfo.txt (2.2 KB)
Hello - can you please try un-checking the ‘enabled’ check box for VRay in Options > Plug-ins page, restart Rhino and see if there is any change in behavior?
yes, the problem makes v-ray…After un-check is drag and drop for image ok…
Hi - V-Ray has fixed this issue for the next release.
As a temporary workaround, you can switch the current render engine to Rhino Render when you need to drag and drop images into the viewport.
