Image import options doesn't work
When i drag any picture in rhino viewport it shows image options window with 5 options (Picture, wallpaper, material, enviroment, texture palette) and picture and wallpaper options are gray (you can;t select it)
What format is the image? Any image?
yes, (doesn’t work both jpg and png)
OK, from inside Rhino, if you run the Picture command, does it allow you to chose the same jpeg or png that doesn’t work with drag and drop and does it create a picture object normally?
Yes, it works with this command !
OK, can you run SystemInfo in Rhino and copy/paste the results here?
Sorry for a delay, here it is:
Rhino 7 SR5 2021-2-22 (Rhino 7, 7.5.21053.09001, Git hash:master @ bfa025d771a5586748502ab53ab7ad9214e81b4a)
License type: Corporate, build 2021-02-22
License details: Stand-Alone
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [96% battery remaining] ~208 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-26-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21053.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21053.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21053.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21053.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21053.9001
One more problem that i forgot to mention(they appeared at once) when i select picture or other plane i have no material toolbar on right menu (take a look at red rectangular) I suppose they are connect
Well there’s unfortunately nothing that can be done for your cracked version of Rhino that is two years and more than 25 service releases old… :astonished:
