if i have sharp angle with “bottom” orientation, then angle dimension is not in center dimension line…
Hi - could you post that 3dm file so that we can check the annotation style?
Thanks!
yes a im sending…
angle_dimension.3dm (295.9 KB)
Hi - I’m not seeing anything in that particular annotation style that is causing this, and making a new style with similar settings does not reproduce this. I’ve created RH-52356 for the developer to take a look.
Thanks!
Hello, after all actualization still not working…
Hi - this was fixed in Rhino 6.16. Which version are you running?
all is ok.
