Angle dimension not working - R8
Hi when I try and dimension an angle it won’t detect the curve in the layout window. Also if I move the model in the layout window the dimensions don’t move with it like normal. Is there a setting that I need to turn on for this to happen?
I have realised that it appears as if it only occurs when the I am trying to dimension things that are with a block
What Osnap(s) are you using to latch onto them?
