is there a way to export Revit to rhino to maintain the geometry layer and the material mapping?
When right clicking and baking Revit Elements with Mapping I am not seeing any issues with Material Mapping. Do you have a specific example? What are you referring to when you say “maintain geometry layer”
Try in a Rendered Viewport
so the graphical element don’t work with revit groups?
thanks, the group member works. another question, after bake, the individual element all become a block, is there way to not block it?
With the materials automatically? No.
You can use Element Geometry or Element View Geometry to get the solid geometry (materials can be derived from sub-categories)
or Element Preview which provides a Mesh with Aligned Materials you could bake.
Try getting the element Dependents in this case (stacked wall is a host, similar to a curtain wall)
Post a small example if you continue to have issues.
thanks, the element dependents works for the stacked wall, but does not working with this stair made out of the floor. when I bake, it only give me the lines, in stead of massing.
Can you provide additional information? Screenshot of your Grasshopper (with panels showing what type of elements and components you are working with), ideally a small revit file (put the version in the file name) Thanks
Revit 2022_Floor_Export to rhino.rvt (692 KB)
thank you
