Revit Section far clip
If you create sections using RhinoInsideRevit, the section does not only look in one direction but in both and the offset rear limit is also locked. It seems to be a bug.
I use RhinoInsideRevit 1.24.9022.17166 (2024-09-13) and Rhino 8.13.24317.13001, 2024-11-12
Could you please share a GH file that illustrate this?
I have attached the Grasshopper script which creates the sections based on a line and saves them in the defined plan. I cannot save the actual Revit project file (to keep it confidential from the customer) but it should be enough to find the possible error.
Test_Wandabwicklung v2.05 - RH8.gh (44.8 KB)
Hi Bjornsmolarek,
You can modify the Far Clipping Parameter by using Element Parameter and an Integer input of 0, 1 or 2.
Hello Japhy,
when I have created the automatically created sections I can set the “Far Clipping” parameter to “Clip with line” afterwards, but when I update it is reset and even with this setting the section is created in both directions, only in the aligned one with a limited cutting depth and in the other it is still infinite.
I use Revit 22 but I get the same result in version 24.
