Cutting Multiple Sections on Grids in Rhino inside Revit/Grasshopper?
I am looking to use Rhino/grasshopper to cut multiple sectional views on grids for Revit. After playing around and researching, i cant seem to get it to work. Is it possible?
Looking foward to the help.
Cheers.
Hi Hayden,
Creating views can be tricky, here is a video with some of the basics.
Hi Japhy,
I have watched this video a couple of times and it doesn’t help with the order for cutting multiple section views on grid.
What Rhino and Revit version are you using?
rhino 8, revit 2023
Here is a quick example using the curve direction to establish a perpendicular facing section at each Grid.
Re-Sections-FromGrids.gh (8.5 KB)
Thanks that works great!
I wanted to add then a typical offset, I have done this, however, it offsets correctly in one direction but not the other. The sections running east/west are correct but not north/south. I want the north/south offest the other side of the grid. What node do i need to insert?
There is no plane input to your offset, derive and deconstruct a plane from the curve (horizontal Frame).
Thanks, got it to work!
If I wanted to control the far clipping offset of the section. How do I isolate so that I can have control over that parameter? Currently, the circled number slider controls the section length but also the far clipping offset.
The far clip is a parameter you can change via Element Parameter
