Hi All, I reference the wall element from a linked model into Grasshopper.
My question is if this wall ID will be changed with a new update/sync for a linked model.
Is these ID unique or will be modified per update?
It will only change if the wall is deleted and recreated, or deleted and undone.
Hi @jia.yeap,
If you need something stable between sessions use ‘Unique ID’.
The
Unique IDis stable across upgrades and workset operations such as Save To Central, while theIdproperty may change.
TheUniqueIDcan be used to store an identifier in an external database and to retrieve the same element in the future if it still exists.
