Rhino.Inside - Revit Linked Air terminals/ Ducts
Im trying to referenced some Revit linked ducts/air terminals in grasshopper with Rhino.Inside but Im getting an invalid/none geometry result. Any help here? Thank you in advance.
Hi PRib, Are those linked elements? I’m not having any issue with that category.
There is a know issue where if a linked project was duplicated from the original it will have the same document ID and fail getting the linked elements. A referenced element count not be found - #27 by parametricmonkey1
Hi @Japhy. Yes, they are linked elements from a consultant revit file. It seems that it can be the same issue as one in the link from just shared.
