Hi, does anyone know if there is a way to use the cut command inside revit from a RiR grasshopper script. E.g. if I wanted to cut the void familes into the walls and slabs in the snap shot:
Hi Julian, That method is for Families i believe.
Here is an example of the InstanceVoidCutUtils.AddInstanceVoidCut method.
Re_add_instance_Cut.gh (5.5 KB)
Thank you so much - that works perfectly
