Hello Everyone,
I’m trying to Cut Revit Walls using Rhino Breb by Python Script since there is no way to do that with native Rhino.Inside, i tried ChatGPT to do the Code for me but unfortunately it doesn’t work properly, i will attached the codes that i got from ChatGPT for Reference,
there is 3 inputs ,
1- a button to execute the code
2- Breb geometry or any other geometry / void could work
3- Revit Walls by using Query Element Component ,
The output should cut the original walls in Revit .
any help will be highly appreciated.
Revit Walls - Void.gh (4.2 KB)
Can you check topic below and let us know if it helps or if you are tryibg to achieve something different.
You have a toggle input.
Void input.
Solid input.
