Hi there,
For some reason the Revit Add In button is greyed out and nothing happens when I click it.
Has anyone else experience this?
Hi there,
I was having the same problem. You need the latest WIP installed.
I had the same problem, did you install latest version ?
If it is greyed out without clicking on it, means is expired, Rhino.Inside Revit expires every 45 days.
It should show an error message warning you 15 days before it expires.
If is not happening this is a bug.
Hi Kike,
Do you mean we have to reinstall it every 45 days?
Hi - as long as a new Rhino version is Work-in-Progress (WIP), it will expire every 45 days. To continue working, you will have to download and install an updated version. New versions are typically released to the public every week.
Anyone else have this issue today after updating?
WIP 7.0.20168.13075
I have the same issue today. Rhino button in Revit interface became grayed out in all Revit versions (2018-2019). I have updated RhinoWIP & RhinoInside few days ago.
Thanks
It appears to be a general issue. Installed RhinoInside + Rhino WIP yesterday and seems to be expired today. Reinstalling Add-in + Rhino WIP does not solve the issue.
Rhino WIP is still running for me. Only Rhino.Inside don’t start.
Same here.
Same problem here. Worked all fine yesterday and have tried to reinstall WIP and revit.inside and restart computer. But no luck so far.
There is a fresh new one ready to download from here.
@kike I reinstalled Rhino WIP and the RIR plug-in. but after restarting my machine, I still have the issue
@kike i also reinstalled both rhino inside and rhino wip, restarted, still no luck
Ups you are right the installer is still the old one.
Looking into this now.
It was a cache issue seems working now.
The new installer should be 3768Kb in size.
Yes, It works well now.
Thank you,
Seems to work for me too.
Thank you
