Hi ,
when opening this file and trying to delete one of the saved views, my machine is crashing every time !
crashtest-02.3dm (418.1 KB)
opened it in R7 WIP and there it seems to be stable…
can someone confirm ?
best
Andreas
Hi ,
best
Andreas
I seem to be able to delete all the named views without a crash… I’m on the latest V6 RC - (6.19.19274.11061, 01-Oct-19)
Thanks !
Weird…
Version 6 SR19
(6.19.19274.11061, 01.10.2019) same version here… I wonder if this is something related to one of my render plugins… enscape / v-ray / octane
OK… this is odd ! It is not something with the file -> just found out that Rhino is now crashing everytime I delete aview … also in other files
Hello - I’d block/disable the plug-ins that you mentioned in Options > Plug-ins page and then restart Rhino and see if the behavior changes - if it works correctly without these, load each of the plug-ins one by one and test - see if you can find which one is the bad guy.
Thanks Pascal, just did that -> enscape is the culprit ! -> will inform them !
best
Andreas
