Delete a view in previes crashes Rhino in Mac
Running Rhino latest version 8.14.24345.15002, 2024-12-10
On Macbook Pro 15.2 Seqouia.
In grashopper I use the View function to jump quickly to where I want to go.
When no longer needed, I want to delete that view, by double clicking the Cross (X) at the right side.
At that moment Rhino crashes . No warning, nothing, Beng
It does not matter what file I am working on, always same behaviour
Any idea how to workaround or solve this?
Regards, Eef
Dag Eef -
I’ll need some hand-holding here. Where do you create, see, and delete those views?
Dag Wim,
Thank you for asking.
See the images (there is a dropdown View)
When I detele one (red cross in right column), most of the time Rhino crashes.
Just now and then, a delete runs fine. But 9 of 10 crash.
Regards, Eef
Dank je, Eef. I can repeat this and will get it on the list.
RH-85451 Grasshopper: Deleting Saved Views Crashes Rhino
RH-85451 is fixed in Rhino 8 Service Release 17
Works just fine. Thank you very much.
still crashing in 25042
Here it is OK. Running on Rhino 8, 8.17.25043.10002
Change settings to service release candidate.
i am on release candidate mac
@giusseppe What is your full version? You need to be using 8.17 for this fix.
sadly I will have to wait until I get a decent signal for download…anyway thanks for fixing it, I look forward to not having the crashes
