We had this issue while using the WIP and unfortunately it is still there with the official V6.
Essentially the named view function is rendered useless, as Rhino crashes whenever a view is double-clicked. I’ve tried it with all files, happens to new files too. Since I couldn’t find this issue in the forums, it could be just us?
A pretty big feature to not have, worked absolutely fine on Windows.
Have you tested this in the SR17 candidate?
In the Rhinoceros pull-down menu, Preferences, General tool, change the update frequency to “Service Release Candidate”. It will download in the background and will give you some updated tools.
So far I can not repeat it.
Can you please post a simple file with a named view that crashes when you try to open it? Please accurately and fully describe which specific interface tools you are using and how. If I can repeat the crash here, I can get it to a developer to find and fix it.
Thanks for taking the time to look at this, John.
However, like I said, it happens to any file. Here is an empty file it happened with.
I have also been having freezing issues with the last candidate, so I reverted to the previous version.
Perhaps there is an apple-side problem to this? crash file.3dm (2.8 MB)
