I have two questions:
- How can I render the backgroundimage in the Rhino renderer?
- How can I render a drawing when it is in the pen mode?
Thanks
Thanks
As far as I know you can’t render in “pen mode”. You can use “Screencapturetofile” or Screencapturetoclipboard" to get the screen to an image. Or you can print the view w/ raster checked and it’ll print to a PDF or printer.
I haven’t used the base Rhino render engine in quite some time. But I think if you go to render properties and choose wallpaper it will render the background image. I’m sure someone else will be able to chime in and verify if I am correct or not.
