Rendering issues with metal
Hi
I thought I’d give the WIP a try on my MacBook Pro especially to try out the metal functionality. Apart from it being a lot slower than version 7 (both with OpenGL and metal), when using metal the display is messed up. I’ll try and attach a screen capture.
systeminfo is as follows:
Rhino 8 SR0 2022-4-26 (Rhino WIP, 8.0.22116.12306, Git hash:master @ 03d671c58e622c1af59c363b7c31025cf8e0f70b)
License type: Commercial, build 2022-04-26
License details: Cloud Zoo
Expires on: 2022-06-10
Apple macOS Version 12.3.1 (Build 21E258) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro15,1
Language: en-NZ (MacOS default)
AMD Radeon Pro 560X OpenGL Engine (OpenGL ver:4.1 ATI-4.8.15)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 560X
Displays: DELL S2721QS (218dpi 2x), Color LCD (258dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro 560X (4 GB)
Color LCD (1680 x 1050)
DELL S2721QS (2560 x 1440 @ 60.00Hz)
USB devices
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp “Constraints UI” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Constraints.rhp “Constraints” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.22116.12306
AFAIK metal works only for m1 processors- this will not work on your amd.
@stevebaer correct me if I’m wrong here,
That is incorrect. Metal works on non-M1 based Apple computers. We will eventually use metal as the display technology for all Macs running Rhino 8.
I’m surprised to hear it is slower than v7 with metal enabled. Can you share this model that is displaying incorrectly?
I’m happy to hear that my Intel Macs will be supported in version 8, you had me worried that I’d need an upgrade.
@Steve Do you have an FTP server that I can upload the model to, it’s quite a large file?
Hi Rick -
Use Rhino - Upload to Support to upload large files. Make sure to copy the URL of this thread into the comments field on that page.
Thanks Wim, I’ve uploaded the file successfully.
Thanks, Rick.
There are quite a few missing image files but that doesn’t seem to matter much - it’s quite a bit slower on Rhino 8 with Metal than on Rhino 7 on my machine as well. I’m sure Steve will take a closer look.
Hi Wim, let me know if you need the image files. They’re just simple textures like steel and bronze, but as the rendering issues occur in shaded mode I don’t think they’re needed as you say.
thanks for the clarification-
